Ana içeriğe geç
Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement
Neye ihtiyacın var
  1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: adım 1, 3 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: adım 1, 3 resimden 2. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Back Cover: adım 1, 3 resimden 3.
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 2, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 2, 2 resimden 2.
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 3, 1 resimden 1.
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: adım 4, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Battery: adım 4, 2 resimden 2.
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 5, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 5, 2 resimden 2.
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
  6. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: adım 6, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Expansion Module: adım 6, 2 resimden 2.
    • Use your finger or a spudger to push up on the small tab on the bottom of the module.
    • Lift the module up and out of its recess bottom first.
  7. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 7, 1 resimden 1.
    • Remove the module.
    • When inserting another module make sure you put it in outputs first. Then push down the bottom part for the tab to engage.
  8. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Midframe: adım 8, 1 resimden 1.
    • Remove the five Torx T4 screws.
  9. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 9, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 9, 2 resimden 2.
    • Place a spudger in the cutout of the extension module to lift the midframe.
    • Be careful not to damage the highway flex cable underneath.
    • Don’t remove the midframe yet. It is still connected to the rest of the OP-Z.
  10. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 10, 3 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 10, 3 resimden 2. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 10, 3 resimden 3.
    • Flip the midframe over to gain access to the flex cable connector underneath.
  11. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 11, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 11, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the flex cable from the front panel assembly.
  12. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: adım 12, 2 resimden 1. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement, Pitch Bend Button: adım 12, 2 resimden 2.
    • Use a spudger or your finger to push the pitch bend button inwards.
  13. Teenage Engineering OP-Z Pitch Bend Rubber Button Replacement: adım 13, 1 resimden 1.
    • Carefully lift and remove the pitch bend button.
    • The button has two small holes which engage with two pins in the midframe.
    • Make sure the two holes and pins align when reinstalling the new button.
Sonuç
Tobias Isakeit
124.278 İtibar
189 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 83
Her zaman: 2,309
