Ana içeriğe geç
Tefal Thick N Thin Toaster 815032 Disassembly
Neye ihtiyacın var
  1. Tefal Thick N Thin Toaster 815032 Disassembly, Tefal Thick N Thin Toaster 815032 Disassembly: adım 1, 3 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly, Tefal Thick N Thin Toaster 815032 Disassembly: adım 1, 3 resimden 2. Tefal Thick N Thin Toaster 815032 Disassembly, Tefal Thick N Thin Toaster 815032 Disassembly: adım 1, 3 resimden 3.
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Disassembly: adım 2, 1 resimden 1.
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Disassembly: adım 3, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly: adım 3, 2 resimden 2.
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
  4. Tefal Thick N Thin Toaster 815032 Disassembly: adım 4, 1 resimden 1.
    • Use an opening tool to pry back the metal tabs on the left and right corners of the toaster's front and back metal panels.
    • Pull off the front and back panels of the toaster.
  5. Tefal Thick N Thin Toaster 815032 Disassembly: adım 5, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly: adım 5, 2 resimden 2.
    • Pry back the metal tabs on the corners of the front and back inner heating panels using an opening tool.
    • Remove both the front and back inner heating panels of the toaster.
  6. Tefal Thick N Thin Toaster 815032 Disassembly: adım 6, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly: adım 6, 2 resimden 2.
    • Now you will have completely disassembled your toaster!
  7. Tefal Thick N Thin Toaster 815032 Disassembly: adım 7, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly: adım 7, 2 resimden 2.
    • We have included a schematic drawing to illustrate how the circuit inside this toaster works.
    • Voltage Source
    • Pushbutton Switch
    • Capacitor: This will cut off the power in the circuit once it gets to a certain voltage.
    • Resistor (Heating Element): The resistor is what creates heat and allows the bread to be toasted.
    • Ground
  8. Tefal Thick N Thin Toaster 815032 Disassembly: adım 8, 3 resimden 1. Tefal Thick N Thin Toaster 815032 Disassembly: adım 8, 3 resimden 2. Tefal Thick N Thin Toaster 815032 Disassembly: adım 8, 3 resimden 3.
    • How it works: When the lever is pressed, the two copper strips are pushed forward and come into contact with an electromagnet that begins the simple toaster circuit.
    • The current flows through a large resistor that wraps around the toaster and slowly gets hot which is what allows the bread to cook.
    • A capacitor connected to the circuit charges through the resistor, and when it reaches a certain voltage it stops the flowing current.
    • The spring immediately pulls the slices of bread up.
    • In the process, the lever rises and cuts off power to the toaster.
    • The darkness setting (below the lever) uses a bi-metallic strip which heats up when the circuit is on and depending on what setting you have it on, the strip bends for a certain amount of time and eventually trips a switch that kills the power to the electromagnet.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 400
