Ana içeriğe geç
Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement
Neye ihtiyacın var
  1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: adım 1, 3 resimden 1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: adım 1, 3 resimden 2. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Side Panels: adım 1, 3 resimden 3.
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: adım 2, 1 resimden 1.
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: adım 3, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement: adım 3, 2 resimden 2.
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
  4. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Front and Back Panels: adım 4, 1 resimden 1.
    • Use an opening tool to pry back the metal tabs on the left and right corners of the toaster's front and back metal panels.
    • Pull off the front and back panels of the toaster.
  5. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: adım 5, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Inner Heating Panels Replacement, Inner Heating Panels: adım 5, 2 resimden 2.
    • Pry back the metal tabs on the corners of the front and back inner heating panels using an opening tool.
    • Remove both the front and back inner heating panels of the toaster.
Sonuç
Kristen Gismondi
81.672 İtibar
200 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.757 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 144
