Ana içeriğe geç
Tefal Thick N Thin Toaster 815032 Side Panels Replacement
Neye ihtiyacın var
  1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: adım 1, 3 resimden 1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: adım 1, 3 resimden 2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement, Side Panels: adım 1, 3 resimden 3.
    • Turn the toaster upside down.
    • Remove the four 10 mm screws from the bottom of the toaster using a TR9 Torx screwdriver.
    • Remove the 14 mm Torx-slot combination screw on the opposite side of the toaster's lever with a TR9 Torx screwdriver.
    • Remove the 11 mm Torx-slot combination screw near the toaster's lever with a TR9 Torx screwdriver.
  2. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: adım 2, 1 resimden 1.
    • Remove the side of the toaster that does not have the lever.
    • The side will just pop off, as you have removed the screw holding it in place.
  3. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: adım 3, 2 resimden 1. Tefal Thick N Thin Toaster 815032 Side Panels Replacement: adım 3, 2 resimden 2.
    • Remove the 10 mm screw from the top of the remaining side of the toaster using a TR9 Torx screwdriver.
    • This side will pop off as well once you have removed the screw.
    • The toaster's lever and heating slide will fall off with a simple pull.
Sonuç
Kristen Gismondi
84.844 İtibar
215 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
141 Üyeler
17.893 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 196
