Ana içeriğe geç
Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement
Neye ihtiyacın var
  1. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement, Door Hook: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two screws attaching the door hook to the backboard.
  2. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 2, 2 resimden 1. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 2, 2 resimden 2.
    • Take the C-bracket and mark the spot where you want to drill.
    • Clamp the C-bracket down onto a piece of wood that you're not worried about drilling into.
    • Be sure the C-bracket is securely in place—otherwise it can spin out.
  3. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 3, 1 resimden 1.
    • Put the power drill on the mark, apply pressure, and drill through to make the screw hole.
    • Always be cautious when using power tools. Be sure to have on eye protection.
  4. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 4, 1 resimden 1.
    • Align the hole of the C-bracket and the mini hoop and stick in the screw.
    • If you are having trouble with this, stick in the screw first and then put the bracket on.
    • Remember to have the hook of the bracket on the backside of the mini hoop so it can hang on the door.
  5. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 5, 3 resimden 1. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 5, 3 resimden 2. Tekk Pro Edition Monster Jam Mini Hoop Door Hook Replacement: adım 5, 3 resimden 3.
    • Screw on the nut onto the screw with your hands.
    • Make sure the nut is tightened securely. Use a wrench if you cannot do it with your hands.
    • Put the mini hoop on a door and test if it holds properly otherwise repeat this step.
Sonuç
C-bracket will be a replacement for the original door hook that came with the mini hoop.
Kunal Dave
121 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 125
