Ana içeriğe geç
Tektro Aires Disc Brakes Brake Pad Replacement
Neye ihtiyacın var
  1. Tektro Aires Disc Brakes Brake Pad Replacement, Brake Pad: adım 1, 1 resimden 1.
    • Bend the retention pins straight using a pair of needle nose pliers.
  2. Tektro Aires Disc Brakes Brake Pad Replacement: adım 2, 2 resimden 1. Tektro Aires Disc Brakes Brake Pad Replacement: adım 2, 2 resimden 2.
    • Loosen the two mounting bolts using a 5mm Hex Key.
    • Different bike models will have the mounting points in different locations.
  3. Tektro Aires Disc Brakes Brake Pad Replacement: adım 3, 1 resimden 1.
    • After removing the bolts pull of the brake caliper from the brake disc.
  4. Tektro Aires Disc Brakes Brake Pad Replacement: adım 4, 1 resimden 1.
    • Using the needle nose pliers remove the retention pin by pulling on it.
  5. Tektro Aires Disc Brakes Brake Pad Replacement: adım 5, 1 resimden 1.
    • Remove the brake pads by pulling on them and realesing them from the caliper.
  6. Tektro Aires Disc Brakes Brake Pad Replacement: adım 6, 1 resimden 1.
    • Place the spring on the new Tektro Disc Brake Pad as shown.
    • The other brake pad will go on the spring opposite the first brake pad.
Sonuç
  • The steps for the front wheel are the same as the back wheel.
  • Follow steps in reverse for reassembly.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 47
Son 30 gün: 221
Her zaman: 3,907
