Ana içeriğe geç
Tektronix TBS1062 Oscilloscope Disassembly
Neye ihtiyacın var
  1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: adım 1, 3 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: adım 1, 3 resimden 2. Tektronix TBS1062 Oscilloscope Disassembly, Removing the front panel: adım 1, 3 resimden 3.
    • Remove all eight plastic buttons.
    • Remove the five Torx T15 screws.
    • Remove the front panel by pulling it off
  2. Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: adım 2, 2 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the back cover: adım 2, 2 resimden 2.
    • Remove the power plug from the cover
    • Firmly grasp the ON/OFF switch and pull it straight out of the box.
    • Press the button into the ON/OFF button recess until it clicks into place.
    • Remove the two black plastic plugs from the bottom.
    • Remove the back cover.
  3. Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: adım 3, 3 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: adım 3, 3 resimden 2. Tektronix TBS1062 Oscilloscope Disassembly, Power supply removal - ATTENTION: adım 3, 3 resimden 3.
    • Even when disconnected, the power supply can retain a dangerously high voltage. Avoid contact with the rear of the board or other components. Use insulated electrician's gloves. Ensure that the capacitors are discharged before touching them.
    • Disconnect the J101 power supply connector from the motherboard.
    • Disconnect the earth connection.
    • Remove the 5x Torx T15 screws.
    • Remove the power supply board.
  4. Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: adım 4, 2 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, Control panel removal: adım 4, 2 resimden 2.
    • Disconnect the black cable from the motherboard
    • Pull the control board plate
  5. Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: adım 5, 3 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: adım 5, 3 resimden 2. Tektronix TBS1062 Oscilloscope Disassembly, Removing the mainboard: adım 5, 3 resimden 3.
    • Loosen the three nuts holding the signal connectors.
    • Loosen the three T15 Torx screws.
    • Remove the cables.
    • Remove the main board.
  6. Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: adım 6, 3 resimden 1. Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: adım 6, 3 resimden 2. Tektronix TBS1062 Oscilloscope Disassembly, LCD display removal: adım 6, 3 resimden 3.
    • Disconnect the ribbon cable and the LCD backlight cable from the motherboard.
    • Loosen the 4x 8mm nuts from the display supports.
    • Remove the LCD display.
Sonuç
Bu çevirmenlere özel teşekkürler:
pt en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Jose Gustavo Abreu Murta
4.794 İtibar
9 adet Kılavuz yazıldı
2 Yorum
This guide is written in English, not Portugese. How can that be changed?
Christopher Sean Harris - Yanıt
Hi Christofer.
Do you intend to translate into Portuguese? I messed up the language when editing it.
Jose Gustavo Abreu Murta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 26
Her zaman: 665
