Giriş
There is a manual for this oscilloscope: TBS1000 Series Service Manual
Complete disassembly is best achieved by following the procedures in the order given in the following table:
1) Rear Feet (See page 6-8, Rear Feet.)
2) Flip Feet (See page 6-9, Flip Feet.)
3) Front-Panel Knobs (See page 6-9, Front-Panel Knobs.)
4) Rear Case (See page 6-10, Rear Case.)
5) Front Feet (See page 6-11, Front Feet.)
6) Power Supply Module (See page 6-12, Power Supply Module.)
7) Internal Assembly (See page 6-13, Internal Assembly.)
8) Front-Panel Cable (See page 6-15, Front-Panel Cable.)
9) Main Board Module (See page 6-16, Main Board Module (without the Display Adapter Module.)
10) Display Module (See page 6-19, Display Module.)
11) Front-Panel Module (See page 6-20, Front-Panel Module.)
12) Keypad|(See page 6-21, Keypad.)
Neye ihtiyacın var
Remove all eight plastic buttons.
Remove the five Torx T15 screws.
Remove the front panel by pulling it off
Remove the power plug from the cover
Firmly grasp the ON/OFF switch and pull it straight out of the box.
Press the button into the ON/OFF button recess until it clicks into place.
Remove the two black plastic plugs from the bottom.
Remove the back cover.
Even when disconnected, the power supply can retain a dangerously high voltage. Avoid contact with the rear of the board or other components. Use insulated electrician's gloves. Ensure that the capacitors are discharged before touching them.
Disconnect the J101 power supply connector from the motherboard.
Disconnect the earth connection.
Remove the 5x Torx T15 screws.
Remove the power supply board.
Disconnect the black cable from the motherboard
Pull the control board plate
Loosen the three nuts holding the signal connectors.
Loosen the three T15 Torx screws.
Remove the cables.
Remove the main board.
Disconnect the ribbon cable and the LCD backlight cable from the motherboard.
Loosen the 4x 8mm nuts from the display supports.
Remove the LCD display.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2Kılavuz Yorumları
This guide is written in English, not Portugese. How can that be changed?
Hi Christofer.
Do you intend to translate into Portuguese? I messed up the language when editing it.
