Ana içeriğe geç
Tello Quadcopter Propeller Replacement
Neye ihtiyacın var
  1. Tello Quadcopter Propeller Replacement, Propeller: adım 1, 1 resimden 1.
    • Identify the propeller being replaced.
    • Gather the required materials.
  2. Tello Quadcopter Propeller Replacement: adım 2, 2 resimden 1. Tello Quadcopter Propeller Replacement: adım 2, 2 resimden 2.
    • Next, remove the battery by grasping each side and pulling it out.
  3. Tello Quadcopter Propeller Replacement: adım 3, 3 resimden 1. Tello Quadcopter Propeller Replacement: adım 3, 3 resimden 2. Tello Quadcopter Propeller Replacement: adım 3, 3 resimden 3.
    • Remove the propeller by inserting the provided tool between the propeller and drone.
    • Needle nose pliers can be used instead. Use the pliers to grasp directly below the propeller.
    • Gently lift the propeller from the socket using your choice of tool.
  4. Tello Quadcopter Propeller Replacement: adım 4, 3 resimden 1. Tello Quadcopter Propeller Replacement: adım 4, 3 resimden 2. Tello Quadcopter Propeller Replacement: adım 4, 3 resimden 3.
    • After removing the old propeller, orient the new propeller over the empty socket.
    • Insert a new propeller by applying force. The propeller should snap into place.
Sonuç
You have successfully completed replacing the damaged propellor.
Cody White
109 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 2,174
