Ana içeriğe geç
Tengda S5 Plus Home Button Replacement
Neye ihtiyacın var
    1. Tengda S5 Plus Home Button Replacement, Back Panel: adım 1, 1 resimden 1.
      • Place the phone screen-side down.
      FixBot'a Sor
      Yorum Ekle
    2. Tengda S5 Plus Home Button Replacement: adım 2, 2 resimden 1. Tengda S5 Plus Home Button Replacement: adım 2, 2 resimden 2.
      • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
      • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
      FixBot'a Sor
      Yorum Ekle
    1. Tengda S5 Plus Home Button Replacement, Battery: adım 3, 1 resimden 1.
      • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
      FixBot'a Sor
      Yorum Ekle
    1. Tengda S5 Plus Home Button Replacement, Home Button: adım 4, 1 resimden 1.
      • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
      • Keep these screws in a safe place. They are very small and easy to lose.
      FixBot'a Sor
      Yorum Ekle
    2. Tengda S5 Plus Home Button Replacement: adım 5, 2 resimden 1. Tengda S5 Plus Home Button Replacement: adım 5, 2 resimden 2.
      • Using the plastic opening tool, create a small gap between the front screen and the metal casing. Slide the plastic opening tool around the phone counterclockwise to make this gap around the entire phone.
      • Once the screen is separated from the back panel, pull the two pieces apart.
      FixBot'a Sor
      Yorum Ekle
    3. Tengda S5 Plus Home Button Replacement: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Lay your device with the screen faced down.
      • Using tweezers, lift the two pieces of yellow tape holding the wire in place.
      FixBot'a Sor
      Yorum Ekle
    4. Tengda S5 Plus Home Button Replacement: adım 7, 2 resimden 1. Tengda S5 Plus Home Button Replacement: adım 7, 2 resimden 2.
      • Using the tweezers again, grasp the wire and free it from the crevice.
      • This will provide slack for you to work with the lower motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Tengda S5 Plus Home Button Replacement: adım 8, 3 resimden 1. Tengda S5 Plus Home Button Replacement: adım 8, 3 resimden 2. Tengda S5 Plus Home Button Replacement: adım 8, 3 resimden 3.
      • Remove the silver tape that holds the lower motherboard to the front panel of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. Tengda S5 Plus Home Button Replacement: adım 9, 2 resimden 1. Tengda S5 Plus Home Button Replacement: adım 9, 2 resimden 2.
      • Using your fingers, or the Metal Spudger, disconnect the black cable connector.
      • The cable connector should easy snap out with little force.
      FixBot'a Sor
      Yorum Ekle
    7. Tengda S5 Plus Home Button Replacement: adım 10, 3 resimden 1. Tengda S5 Plus Home Button Replacement: adım 10, 3 resimden 2. Tengda S5 Plus Home Button Replacement: adım 10, 3 resimden 3.
      • Using your fingers, slide the lower motherboard towards you.
      • The lower motherboard will still be attached to the front panel by a red and blue cable on the left side and a long silver wire on the right side, but you should now have visibility of the home button.
      FixBot'a Sor
      Yorum Ekle
    8. Tengda S5 Plus Home Button Replacement: adım 11, 2 resimden 1. Tengda S5 Plus Home Button Replacement: adım 11, 2 resimden 2.
      • Clean away any dirt from the back side of the lower motherboard, underneath the charging port.
      • Using tweezers, grasp and remove the home button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kenny Levy
128 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G9
4 Üyeler
35 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 37
Her zaman: 728
