Ana içeriğe geç
Tengda S5 Plus Rear Camera Replacement
Neye ihtiyacın var
  1. Tengda S5 Plus Rear Camera Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the phone screen-side down.
  2. Tengda S5 Plus Rear Camera Replacement: adım 2, 2 resimden 1. Tengda S5 Plus Rear Camera Replacement: adım 2, 2 resimden 2.
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Rear Camera Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
  4. Tengda S5 Plus Rear Camera Replacement, Rear Camera: adım 4, 1 resimden 1.
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
    • Keep these screws in a safe place. They are very small and easy to lose.
  5. Tengda S5 Plus Rear Camera Replacement: adım 5, 2 resimden 1. Tengda S5 Plus Rear Camera Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Rear Camera Replacement: adım 6, 1 resimden 1.
    • Place the phone facing screen down.
    • Using the plastic prying tool, gently disconnect the black connector cable.
    • The connector cable should easy snap out with little force.
  7. Tengda S5 Plus Rear Camera Replacement: adım 7, 1 resimden 1.
    • Using the plastic prying tool, pry the camera from the tape holding it in place.
    • Be careful not to rip the tape.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jholmesford
224 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G9
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 407
