Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
Continue to work your way around the phone counterclockwise until you can pull the back cover off.
Remove the battery by placing your thumb in the slot, pushing the battery up and pulling it out.
Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
Using the plastic opening tool, create space between the front screen and the metal casing.
Once the screen is separated from the back panel, pull the two pieces apart.
Place the phone facing screen down.
Using the plastic prying tool, gently disconnect the black connector cable.
Using the plastic prying tool, pry the camera from the tape holding it in place.
2 farklı kişi bu kılavuzu tamamladı.
