Ana içeriğe geç
Tengda S5 Plus Speakers Replacement
Neye ihtiyacın var
  1. Tengda S5 Plus Speakers Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the phone screen-side down.
  2. Tengda S5 Plus Speakers Replacement: adım 2, 2 resimden 1. Tengda S5 Plus Speakers Replacement: adım 2, 2 resimden 2.
    • Using your fingernail or any prying tool (we used the Metal Spudger), begin to pry away the back panel starting at the bottom of the phone.
    • Continue to work your way around the phone counterclockwise until you can pull the back cover off.
  3. Tengda S5 Plus Speakers Replacement, Speakers: adım 3, 1 resimden 1.
    • Using either your thumb or an iFixit opening tool, remove the battery and set it aside.
  4. Tengda S5 Plus Speakers Replacement: adım 4, 1 resimden 1.
    • Unscrew the twelve 3 mm screws from the back panel using a Phillips #00 screwdriver.
  5. Tengda S5 Plus Speakers Replacement: adım 5, 2 resimden 1. Tengda S5 Plus Speakers Replacement: adım 5, 2 resimden 2.
    • Using the plastic opening tool, create space between the front screen and the metal casing.
    • Once the screen is separated from the back panel, pull the two pieces apart.
  6. Tengda S5 Plus Speakers Replacement: adım 6, 2 resimden 1. Tengda S5 Plus Speakers Replacement: adım 6, 2 resimden 2.
    • Using an iFixit opening tool, remove the speakers.
    • Do not be afraid to use a little force. The speakers are glued onto the phone, not wired.
Sonuç
Andrew Lam
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Amido Spring 2015 Cal Poly, Team 14-9, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G9
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 343
