Giriş
You will be cutting the strings off the tennis racket and taking off the old bumper guard. Then you are going to replace it with a new bumper guard. You will have to do the netting on your own, or take it to a store to get it done. You can either use utility scissors or nail clippers to cut the strings.
Neye ihtiyacın var
Place the tennis racket on a big and comfortable surface. An empty table will be ideal.
As you push the tubes from the bumper guard and grommets they will start to come out.
The second picture shows the bumper guard and grommets completely removed.
Depending on your tennis racket another grommet might located at the base of the racket represented by the orange mark up. Remove it if it is present.
Now you can take your tennis racket to get restrung and you should have a finished racket.
2 farklı kişi bu kılavuzu tamamladı.
