Ana içeriğe geç
Tesla Keyfob Battery Replacement
Neye ihtiyacın var
  1. Tesla Keyfob Battery Replacement, Remove the battery cover: adım 1, 2 resimden 1. Tesla Keyfob Battery Replacement, Remove the battery cover: adım 1, 2 resimden 2.
    • Lever up the battery cover by using a small screwdriver or similar device.
    • Do not attempt to open the side of the keyfob that contains the key ring. The "front" of the fob is the removable portion.
    FixBot'a Sor
  2. Tesla Keyfob Battery Replacement, Remove the battery: adım 2, 3 resimden 1. Tesla Keyfob Battery Replacement, Remove the battery: adım 2, 3 resimden 2. Tesla Keyfob Battery Replacement, Remove the battery: adım 2, 3 resimden 3.
    • Using the same lever device used to remove the cover, lever out the battery where indicated.
    • Remove the battery
    • Replace the battery with your replacement CR2032 in the same manner as it was removed.
    FixBot'a Sor
  3. Tesla Keyfob Battery Replacement, Reassemble the Keyfob: adım 3, 1 resimden 1.
    • Install the cover once the battery has been inserted.
    FixBot'a Sor
Sonuç
And that’s it! Go for a drive!
Bir başkası bu kılavuzu tamamladı.
Michael Snively
124 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 51
Her zaman: 586
