Ana içeriğe geç
Tesla Model S Key Fob Battery Replacement
Neye ihtiyacın var
  1. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 1. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 2. Tesla Model S Key Fob Battery Replacement, Key Fob Battery: adım 1, 3 resimden 3.
    • Remove the protective case from the key fob.
    • This step is optional; not everyone has a protective case.
  2. Tesla Model S Key Fob Battery Replacement: adım 2, 3 resimden 1. Tesla Model S Key Fob Battery Replacement: adım 2, 3 resimden 2. Tesla Model S Key Fob Battery Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of a spudger into the notch, and gently pry the key fob open along the seam.
    • Separate the cover from the key fob.
  3. Tesla Model S Key Fob Battery Replacement: adım 3, 3 resimden 1. Tesla Model S Key Fob Battery Replacement: adım 3, 3 resimden 2. Tesla Model S Key Fob Battery Replacement: adım 3, 3 resimden 3.
    • Insert the flat end of a spudger into the entry point at the top of the key fob.
    • Lightly push the spudger under the battery.
    • Remove the battery from the key fob.
  4. Tesla Model S Key Fob Battery Replacement: adım 4, 3 resimden 1. Tesla Model S Key Fob Battery Replacement: adım 4, 3 resimden 2. Tesla Model S Key Fob Battery Replacement: adım 4, 3 resimden 3.
    • With your fingers, insert a new CR2032 battery into the opening.
    • Ensure correct placement of the battery by having the writing facing up toward you and the blank side with a number facing down inside the battery opening.
    • Push the battery with your thumb to lock it into place.
  5. Tesla Model S Key Fob Battery Replacement: adım 5, 3 resimden 1. Tesla Model S Key Fob Battery Replacement: adım 5, 3 resimden 2. Tesla Model S Key Fob Battery Replacement: adım 5, 3 resimden 3.
    • To close the key fob, enter the wider side of the cover into the opening in the middle of the key fob.
    • You should see the end of the cover a little popped out.
    • With your thumb and pointer finger push together the cover and the key fob to allow for the key fob to be securely closed.
  6. Tesla Model S Key Fob Battery Replacement: adım 6, 3 resimden 1. Tesla Model S Key Fob Battery Replacement: adım 6, 3 resimden 2. Tesla Model S Key Fob Battery Replacement: adım 6, 3 resimden 3.
    • This step is optional (not everyone has a case).
    • Place the key fob into the opening of the case.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Stefanie Ayala
175 İtibar
1 Kılavuz yazıldı
Bir Yorum
Really, that tip was helpful, the last time i my model s tesla key fob's battery was dead, I order another on amazon, and some tips online here on tesla key fob programming. At first, I was a little bit skeptical given that I have not done such a thing before on my tesla. However, the process was really simple and the guide on the site was helpful.
Ayo Idowu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 67
Her zaman: 4,928
