Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Set up a ladder in a level place outside that you don't mind getting wet.
Turn the waders inside out.
Clip the waders to the ladder.
Put the hose into the waders.
Slide the hose into one leg of the waders.
Watch for leaks. When you find a leak, mark it with a permanent marker.
Repeat this process for the other leg, marking all the leaks you find.
Dump the water out and allow the waders to dry completely before you continue.
