Giriş
A detailed guide on how to use a continuity tester to check for adequate electrical connection on a power cord.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Set the multimeter to continuity test mode.
Verify that the positive lead is plugged to the voltmeter/ ohmmeter outlet.
126 farklı kişi bu kılavuzu tamamladı.
13 Yorum
Great Article,you can use a little bubble to let electric current light the bubble,make sure use the correct voltage of ,Example ,if you are in Europe,then you need to use 220V Europe power cord http://www.yunhuanelectric.com/Europe-po... to test.
Thank you very much.
Wow Wow Just a Great Guide, Now I have learned one more skill :)
Brilliant love it
Superb...thanks a lot!!
Now I know how to test a power cord.
How do I test a switch?
Can you do a continuity test on the Xbox One Original CONSOLE ?
An electrician respond your call within an hour in dubai . so they have guideline to do electrical work with safety. <a href="https://handyman-dubai.com/electrician-d...>electrician in dubai</a> they have tools of testing power all time with them . they resolve issue with that.
