Ana içeriğe geç
Texas Instruments TI BA II PLUS Battery Replacement
Neye ihtiyacın var
  1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: adım 1, 2 resimden 1. Texas Instruments TI BA II PLUS  Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Switch off the calculator by pressing the button at the top right corner.
  2. Texas Instruments TI BA II PLUS  Battery Replacement: adım 2, 1 resimden 1.
    • Turn over the calculator so the backside of the calculator is facing upwards.
    • Remove the four 2mm Phillips #00 screws from the bottom cover.
  3. Texas Instruments TI BA II PLUS  Battery Replacement: adım 3, 1 resimden 1.
    • Open a small gap at the bottom of the calculator, using a spudger or your fingers.
    • Move your thumb from the bottom edge to the top.
    • Be gentle when separating the cases to avoid breaking the clips.
  4. Texas Instruments TI BA II PLUS  Battery Replacement: adım 4, 3 resimden 1. Texas Instruments TI BA II PLUS  Battery Replacement: adım 4, 3 resimden 2. Texas Instruments TI BA II PLUS  Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to remove the battery from the cage at the bottom of the motherboard.
  5. Texas Instruments TI BA II PLUS  Battery Replacement: adım 5, 1 resimden 1.
    • Replace the battery with the new CR2032 Lithium Battery in the battery cage.
  6. Texas Instruments TI BA II PLUS  Battery Replacement: adım 6, 2 resimden 1. Texas Instruments TI BA II PLUS  Battery Replacement: adım 6, 2 resimden 2.
    • Reattach the calculator cases, beginning from the top edge.
    • Use the Phillips #00 screwdriver to replace the 2.00 mm screws.
Bitiş Çizgisi
5 farklı kişi bu kılavuzu tamamladı.
Peipei Yu
268 İtibar
1 Kılavuz yazıldı
3Kılavuz Yorumları
It's amazing that this calculator can break. I am an accountant student in college and despite modern technologies and the rather powerful functionality of modern smartphones, I like to use just such a calculator for financial calculations.
AlGorFun - Yanıt
Great guide, thanks! The spudger was necessary for me to separate the case, as I couldn’t separate it with my fingers alone.
Jonathan - Yanıt
使用2.5mm的螺丝刀更好,2mm可能会打滑
C Max - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 60
Son 30 gün: 300
Her zaman: 27,874
