Giriş
This guide will teach you how to remove and replace the battery to the TI-30XS Multiview. Be sure to note the orientation of the battery for when a new one is being put in.
Neye ihtiyacın var
Using the #00 screwdriver, unscrew the six, 6mm Phillips screws.
Use the spudger to pry into the space between the blue back cover and the white body to take off the back cover.
Using the #00 Phillips screwdriver unscrew the two, 3mm Phillips screws located near the top of the calculator.
Lift the metal plate from the battery and set it to the side.
Use the spudger to lift the battery up from the black holder.
Funktioniert beim 30X Pro Multiview gleich?
Is a spudger really necessary. I don't have it, just the phillips 00 screwdriver. Do I need to go out and buy one of these?
You can just use a fingernail to open it.
Put the new CR2032 battery in. Never insert a different type of battery!
Reverse the steps 2 and 1.
my TI-30XS battery was mounted directly onto the circuit board under a metal clip, the black battery holder doesn't exist at all. Anyway the battery is the still the same CR2032.
16 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Hi, I followed your steps but my battery cover is not in the location that your photo indicates and the cover screws are not visible. There seems to be something covering them?
Why would my battery be situated next to the round black thing and yours is located above it at the top? If the calculator is a TI-XS 30 Multiview why on earth would they vary the orientation of internal components?
(I have had this calculator since 2006 - 12 years - it died this morning and I am disconsolate. Please help me figure out how to take the battery cover off or convince me to dispose of it.) ….I hate throwing away a good machine, even if I need to buy a more up to date graphing machine.
Eric of Ann Arbor
eric@engeltutors.com
Please note - My battery screws (the ones that were inside the calculator next to battery) were actually glued over. I had to push the old battery out with my screw driver and push it out manually. It worked though. Glad I didn’t have to toss it, one less thing going into the land-field.
Wait a minute. Why does this calculator need a battery if it has a solar cell. It must be a fake solar cell to deceive.
It charges the CR2032.
You can shine a light on the panel and remove the battery and the calculator will still work.
It should be mentioned that you should insert a rechargable ML2032 instead of a common non-rechargable CR2032, since the solar panel will recharge the battery and standard CR2032 batteries are non-rechargable.
Thank you for the clear instructions! I love this simple scientific calculator and glad to have fixed after 10 years of reliable use. I'm also happy to keep it out of the landfill for now!
Unfortunately, I replaced the battery with a new one and the calculator still doesn't turn on. Shame.
A 2016 battery can be used if you don't have a 2032. It is thinner, so will not last as long, perhaps only a few years, but has the same voltage.
I didn’t have a spudger but a flat 3/32” jeweler’s screwdriver worked just as well. Also, the battery slides out the side, nothing to undo. I slid it out using a jeweler’s screwdriver. (Don’t touch any electrical components or traces with the metal tip.) If you’re not sure the battery is good, turn the unit over and see if there is anything displaying, or run a test operation like 2 x 2 etc. to check before putting the back into place.
Therese S - Yanıt
