Ana içeriğe geç
Texas Instruments TI-30X IIS Battery Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: adım 1, 3 resimden 1. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: adım 1, 3 resimden 2. Texas Instruments TI-30X IIS Battery Replacement, Device Inspection: adım 1, 3 resimden 3.
    • Ensure that your calculator is a TI-30X IIS by looking in the top right corner of the front face.
    • Look at the rear face of the calculator and locate the four case screws. There are two at the top and two at the bottom.
  2. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: adım 2, 2 resimden 1. Texas Instruments TI-30X IIS Battery Replacement, Removing Screws: adım 2, 2 resimden 2.
    • Use a Philips 00 screwdriver to remove the four case screws on the rear face of the calculator.
    • Be sure to save the screws in a secure place as they are small and easy to lose. They will be needed later for reassembly.
  3. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: adım 3, 3 resimden 1. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: adım 3, 3 resimden 2. Texas Instruments TI-30X IIS Battery Replacement, Unclipping Case: adım 3, 3 resimden 3.
    • With all four screws removed, use a flathead screwdriver or similar flat object to separate the front and rear casings.
    • There are six clips that keep the cases together. These areas will require extra force to separate, but use caution to not fracture the plastic pieces.
  4. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: adım 4, 3 resimden 1. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: adım 4, 3 resimden 2. Texas Instruments TI-30X IIS Battery Replacement, Removing Battery: adım 4, 3 resimden 3.
    • With the rear case off, the battery is exposed and accessible.
    • Using a pointed tool, slide the battery out of its terminal towards the near edge.
    • Once the battery is protruding from the contacts, remove it with your fingers.
  5. Texas Instruments TI-30X IIS Battery Replacement, Replacing Battery: adım 5, 1 resimden 1.
    • Properly dispose of the old battery.
    • Replace the battery with an identical one, positive terminal up and negative terminal facing down towards the circuit board.
    • Following the previous steps in the reverse order to reassemble the calculator.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Ryan
515 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 163
Her zaman: 33,218
