Ana içeriğe geç
Texas Instruments TI-30Xa Battery Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-30Xa Battery Replacement, TI-30XA Battery Replacement: adım 1, 1 resimden 1.
    • Here's the fully assembled TI-30XA calculator.
  2. Texas Instruments TI-30Xa Battery Replacement: adım 2, 2 resimden 1. Texas Instruments TI-30Xa Battery Replacement: adım 2, 2 resimden 2.
    • Locate the six screws on the back of the calculator.
    • With a Phillips #0 screwdriver, loosen and remove the screws.
  3. Texas Instruments TI-30Xa Battery Replacement: adım 3, 3 resimden 1. Texas Instruments TI-30Xa Battery Replacement: adım 3, 3 resimden 2. Texas Instruments TI-30Xa Battery Replacement: adım 3, 3 resimden 3.
    • Find the two notches at the top of the calculator.
    • Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
    • Locate where the case is still attached at the sides.
    • Insert the flat-head screwdriver into one side where the gap has widened.
    • Now gently pry apart the sides of the case.
    • Prying only one side will release the other side as well.
  4. Texas Instruments TI-30Xa Battery Replacement: adım 4, 1 resimden 1.
    • Now separate the two panels from one another.
  5. Texas Instruments TI-30Xa Battery Replacement: adım 5, 2 resimden 1. Texas Instruments TI-30Xa Battery Replacement: adım 5, 2 resimden 2.
    • The two LR44 batteries are located at the top.
    • Slide the flat-head screwdriver underneath each battery and they will easily pop out.
Sonuç
56 farklı kişi bu kılavuzu tamamladı.
Chris L
1.546 İtibar
3 adet Kılavuz yazıldı
30Kılavuz Yorumları
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
Scott Julien - Yanıt
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Dewellah - Yanıt
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
lasharlavenue - Yanıt
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
Esther Reese - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 64
Son 30 gün: 345
Her zaman: 117,700
