Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the six screws on the back of the calculator.
With a Phillips #0 screwdriver, loosen and remove the screws.
Find the two notches at the top of the calculator.
Insert a flat-head screwdriver into one of the notches and carefully pry open the top end of the case.
Locate where the case is still attached at the sides.
Insert the flat-head screwdriver into one side where the gap has widened.
Now gently pry apart the sides of the case.
The two LR44 batteries are located at the top.
Slide the flat-head screwdriver underneath each battery and they will easily pop out.
55 farklı kişi bu kılavuzu tamamladı.
30 Yorum
Thx a bunch!
Thanks for the guide! :) Worked! (Although they didn't engineer the case to come apart easily...)
I'm so glad I looked this up. VERY helpful. A simple Google search indicated that it took a 3 volt, flat 'coin' style battery. These batteries, however - I actually have in my desk at work in a 3 pack. No need to even take a trip to the store now. Oh, BTW - the 3 pack was purchased from Walgreens. They sell them in a 3 pack for around $10.
Nice post! My batteries just gave up after 15 years. This whole time I tht it was a solor calc, LOL! Thanks for the easy instructions.
I changed the batteries and instructions on circuit board says to "please short the reset pad after changing the batteries ". How do I do that?
