Ana içeriğe geç
Texas Instruments TI-5130 Printer Unit Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: adım 1, 2 resimden 1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: adım 1, 2 resimden 2.
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Texas Instruments TI-5130 Printer Unit  Replacement: adım 2, 1 resimden 1.
    • Flip the calculator back over and remove the top cover.
    FixBot'a Sor
    Yorum Ekle
  3. Texas Instruments TI-5130 Printer Unit  Replacement: adım 3, 1 resimden 1.
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  4. Texas Instruments TI-5130 Printer Unit  Replacement: adım 4, 1 resimden 1.
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
    FixBot'a Sor
    Yorum Ekle
  5. Texas Instruments TI-5130 Printer Unit  Replacement: adım 5, 2 resimden 1. Texas Instruments TI-5130 Printer Unit  Replacement: adım 5, 2 resimden 2.
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shannon Perkins
652 İtibar
3 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
wehre did you buy the replacement printer
Tino ullrich - Yanıt Paylaş
what sources are there for TI-5130 printer unit?
Norman Todd - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 2,975
