Ana içeriğe geç
Texas Instruments TI-5130 Printer Unit Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: adım 1, 2 resimden 1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: adım 1, 2 resimden 2.
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
  2. Texas Instruments TI-5130 Printer Unit  Replacement: adım 2, 1 resimden 1.
    • Flip the calculator back over and remove the top cover.
  3. Texas Instruments TI-5130 Printer Unit  Replacement: adım 3, 1 resimden 1.
    • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
  4. Texas Instruments TI-5130 Printer Unit  Replacement: adım 4, 1 resimden 1.
    • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
  5. Texas Instruments TI-5130 Printer Unit  Replacement: adım 5, 2 resimden 1. Texas Instruments TI-5130 Printer Unit  Replacement: adım 5, 2 resimden 2.
    • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
    • Remove the printer unit by lifting it up.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Shannon Perkins
652 İtibar
3 adet Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
wehre did you buy the replacement printer
Tino ullrich - Yanıt
what sources are there for TI-5130 printer unit?
Norman Todd - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 34
Her zaman: 2,524
