Ana içeriğe geç
Texas Instruments TI-80 Back Casing Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-80 Back Casing Replacement, Batteries: adım 1, 1 resimden 1.
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Back Casing Replacement: adım 2, 1 resimden 1.
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Back Casing Replacement, Back Case: adım 3, 3 resimden 1. Texas Instruments TI-80 Back Casing Replacement, Back Case: adım 3, 3 resimden 2. Texas Instruments TI-80 Back Casing Replacement, Back Case: adım 3, 3 resimden 3.
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
Sonuç
Calvin
201 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 67
Her zaman: 533
