Ana içeriğe geç
Texas Instruments TI-80 Keyboard Mat Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-80 Keyboard Mat Replacement, Batteries: adım 1, 1 resimden 1.
    • Locate battery cover on the back of the case.
    • Slide battery cover to the right reveal the batteries.
  2. Texas Instruments TI-80 Keyboard Mat Replacement: adım 2, 1 resimden 1.
    • Remove battery cover.
    • Slide the red lock down.
    • Slide the metal tab to the right of the top battery.
    • Remove the 3-Volt Lithium Coin Cell Battery.
    • Slide the red lock up.
    • Slide the metal tab to the right of the bottom battery.
  3. Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: adım 3, 3 resimden 1. Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: adım 3, 3 resimden 2. Texas Instruments TI-80 Keyboard Mat Replacement, Back Case: adım 3, 3 resimden 3.
    • Using a Torx, T-6 star-bit screwdriver, unscrew four 7.38 mm screws from battery housing.
    • Unscrew four 7.15 mm screws from back casing.
    • Using the blue plastic opener tool along the seam of the case, pry off front casing.
    • Start prying from the bottom of the calculator as the casing hooks into the top.
  4. Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: adım 4, 2 resimden 1. Texas Instruments TI-80 Keyboard Mat Replacement, Motherboard and Screen: adım 4, 2 resimden 2.
    • Using a Philips PH0 screwdriver, remove the 6 screws. 2 from the top of the Motherboard, 2 from the middle, and 2 from the bottom of the Motherboard.
    • Using a Phillips Ph0 screwdriver, remove 4 screws from the screen mount.
    • Using the blue plastic opening tool, pry the Motherboard up.
    • Using the blue plastic opening tool, pry up the screen from the screen mount.
  5. Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: adım 5, 2 resimden 1. Texas Instruments TI-80 Keyboard Mat Replacement, Check keyboard mat: adım 5, 2 resimden 2.
    • Check the rubber mat for damage or obstruction at the location of non-functioning buttons.
    • Flip the mat over to assess dirt and damage.
    • Replace the mat if it is damaged.
    • Clean off the back of the Motherboard as necessary. The mat lies on top, so dirt and debris may build up. Repeat cleaning as needed.
Sonuç
brian decater
301 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 303
