Ana içeriğe geç
Texas Instruments TI-83 Plus Back Case Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-83 Plus Back Case Replacement, Backup Battery: adım 1, 2 resimden 1. Texas Instruments TI-83 Plus Back Case Replacement, Backup Battery: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Back Case Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Back Case Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Back Case Replacement, Back Case: adım 4, 1 resimden 1.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Back Case Replacement: adım 5, 2 resimden 1. Texas Instruments TI-83 Plus Back Case Replacement: adım 5, 2 resimden 2.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jared
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G37
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 39
Her zaman: 10,069
