Ana içeriğe geç
Texas Instruments TI-83 Plus Backup Battery Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: adım 1, 2 resimden 1. Texas Instruments TI-83 Plus Backup Battery Replacement, Backup Battery: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Backup Battery Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Backup Battery Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
Sonuç
Clay
38 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G37
5 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
Will this wipe the memory?
John Osborne - Yanıt
Yes I found one and have been trying to get it together for a high schooler I had one when I took trig in college and it was very helpful
Jack Irvin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 93
Her zaman: 22,581
