Ana içeriğe geç
Texas Instruments TI-83 Plus Individual Keys Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: adım 1, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
    FixBot'a Sor
    Yorum Ekle
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
    FixBot'a Sor
    Yorum Ekle
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    FixBot'a Sor
    Yorum Ekle
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: adım 4, 1 resimden 1.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
    FixBot'a Sor
    Yorum Ekle
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 5, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 5, 2 resimden 2.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    FixBot'a Sor
    Yorum Ekle
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: adım 6, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: adım 6, 2 resimden 2.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 7, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 7, 2 resimden 2.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
    FixBot'a Sor
    Yorum Ekle
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: adım 8, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: adım 8, 2 resimden 2.
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
    FixBot'a Sor
    Yorum Ekle
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 9, 1 resimden 1.
    • Clean the contacts on the keyboard with a soft cloth.
    FixBot'a Sor
    Yorum Ekle
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: adım 10, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jared
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G37
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 59
Her zaman: 5,448
