Ana içeriğe geç
Texas Instruments TI-83 Plus Individual Keys Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: adım 1, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
  4. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: adım 4, 1 resimden 1.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 5, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 5, 2 resimden 2.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
  6. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: adım 6, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: adım 6, 2 resimden 2.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 7, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 7, 2 resimden 2.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
  8. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: adım 8, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: adım 8, 2 resimden 2.
    • Remove light gray rubber keyboard mat.
    • Keep your calculator face down to ensure the individual keys do not fall out.
  9. Texas Instruments TI-83 Plus Individual Keys Replacement: adım 9, 1 resimden 1.
    • Clean the contacts on the keyboard with a soft cloth.
  10. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: adım 10, 2 resimden 1. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: adım 10, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove one key at a time.
    • Be sure to keep them organized if you are taking out multiple keys.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jared
156 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G37
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 38
Her zaman: 4,875
