Ana içeriğe geç
Texas Instruments TI-83 Plus Motherboard & Screen Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: adım 1, 2 resimden 1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Backup Battery: adım 1, 2 resimden 2.
    • Remove the battery cover.
    • Remove the AAA batteries from the calculator.
  2. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 2, 1 resimden 1.
    • Remove the 5mm Philips #00 screw holding backup battery cover.
    • Remove the backup battery cover.
  3. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 3, 1 resimden 1.
    • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
    • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
    Can confirm. The battery has a tendency to launch itself out of the bay!
    Jerad - Yanıt
  4. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Back Case: adım 4, 1 resimden 1.
    • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
  5. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 5, 2 resimden 1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 5, 2 resimden 2.
    • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
    I had to apply quite a bit of pressure to split the halves. I almost thought the sides would break, but they didn't.
    Jerad - Yanıt
    I'm sure this is assumed, but this guide also worked on the Silver Edition of the 83-Plus -- just in case anyone was curious.
    Jerad - Yanıt
  6. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: adım 6, 2 resimden 1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement, Motherboard & Screen: adım 6, 2 resimden 2.
    • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
    • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
  7. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 7, 2 resimden 1. Texas Instruments TI-83 Plus Motherboard & Screen Replacement: adım 7, 2 resimden 2.
    • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
    • Keep the face-plate face-down to prevent the keys from falling out.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Kevin
479 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-37, Regan Fall 2012 Cal Poly, Team 18-37, Regan Fall 2012 üyesi
CPSU-REGAN-F12S18G37
5 Üyeler
5 adet Kılavuz yazıldı
15 Yorum
Does anyone have any advice on acquiring replacement screens for the TI series? I was considering buying broken TIs on e-bay, but that may be unreliable.
Neil Cammardella - Yanıt
Fixing TI83+'s is becoming addictive. Google Cemetech Forum on the net and see how he removes the screen from the Mother Board and solders wires permanently. I might add that he tests for resistance (ohms) first to determine if in fact that is where the problems exist. If I read between the lines, he tends to think that the screen/mother board ribbon cable is the primary culprit behind problems with the TI83's
shrinertom@yahoo.com
shrinertom -
My TI-83 Plus, the screen has turned Black, like to know where to send it to have it repaired e-mail address, (BagManOne@ecite.com)
Richard Brown - Yanıt
Nothing is broken, the screen has turned Black, need to send it off and have it fixed, I can not do it my self because of the condition of my hands
Richard Brown -
It may not be broken. Try adjusting the screen contrast down.
Matthew Johnson -
All I needed was to know the T6 Screwdriver size, the carved-out screw-holes made me less worried about the bits of plastic coming out of mine. Thanks!
finleywarman - Yanıt
Is it uncommon to have an aluminum sheet attached to the piece of paper with the battery markings on it or is this just me?
Ethan T - Yanıt
only half of my screen shows, how do I fix that?
stephanie13318 - Yanıt
Hello,
My TI-83 has a black screen, I tried adjusting the contrast but it doesn't work.
Any Ideas on what else to try
Thank You !
Pedro Esquivel - Yanıt
My calculator cuts off half of the first digit I put in. How do I fix this?
Hailey Ober - Yanıt
How much to get thr screen or motherhood fix with a black line across the screen?
charryon12 - Yanıt
How much to get thr screen or motherhood fix with a black line across the screen? In
charryon12 - Yanıt
Where could I go about finding a new screen for one of these calculators?
Lorelei Rareheart - Yanıt
Buying a new screen is hard because the wires are soldered to the board. Buy a working ti83 plus off of ebay for maybe a max of 25$. If you dont want a used one, just upgrade to a ti84plus or plus-ce. But, if your ti83plus is very important to you, buying a working one off of ebay and swap the motherboards and screens.
Nokia User - Yanıt
FYI: Newer TI-83s have the board riveted into the plastic.
Lee Hunt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 35
Son 30 gün: 119
Her zaman: 49,221
