Ana içeriğe geç
Texas Instruments TI-92 Batteries Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-92 Batteries Replacement, Back Cover: adım 1, 3 resimden 1. Texas Instruments TI-92 Batteries Replacement, Back Cover: adım 1, 3 resimden 2. Texas Instruments TI-92 Batteries Replacement, Back Cover: adım 1, 3 resimden 3.
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
    FixBot'a Sor
    Yorum Ekle
  2. Texas Instruments TI-92 Batteries Replacement: adım 2, 2 resimden 1. Texas Instruments TI-92 Batteries Replacement: adım 2, 2 resimden 2.
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
    FixBot'a Sor
    Yorum Ekle
  3. Texas Instruments TI-92 Batteries Replacement: adım 3, 2 resimden 1. Texas Instruments TI-92 Batteries Replacement: adım 3, 2 resimden 2.
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
    FixBot'a Sor
    Yorum Ekle
  4. Texas Instruments TI-92 Batteries Replacement, Batteries: adım 4, 3 resimden 1. Texas Instruments TI-92 Batteries Replacement, Batteries: adım 4, 3 resimden 2. Texas Instruments TI-92 Batteries Replacement, Batteries: adım 4, 3 resimden 3.
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Daniel Maldonado
264 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G51
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 19
Son 30 gün: 71
Her zaman: 8,091
