Ana içeriğe geç
Texas Instruments TI-92 Motherboard Replacement
Neye ihtiyacın var
  1. Texas Instruments TI-92 Motherboard Replacement, Back Cover: adım 1, 3 resimden 1. Texas Instruments TI-92 Motherboard Replacement, Back Cover: adım 1, 3 resimden 2. Texas Instruments TI-92 Motherboard Replacement, Back Cover: adım 1, 3 resimden 3.
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
    FixBot'a Sor
    Yorum Ekle
  2. Texas Instruments TI-92 Motherboard Replacement: adım 2, 2 resimden 1. Texas Instruments TI-92 Motherboard Replacement: adım 2, 2 resimden 2.
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
    FixBot'a Sor
    Yorum Ekle
  3. Texas Instruments TI-92 Motherboard Replacement: adım 3, 2 resimden 1. Texas Instruments TI-92 Motherboard Replacement: adım 3, 2 resimden 2.
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
    FixBot'a Sor
    Yorum Ekle
  4. Texas Instruments TI-92 Motherboard Replacement, Batteries: adım 4, 3 resimden 1. Texas Instruments TI-92 Motherboard Replacement, Batteries: adım 4, 3 resimden 2. Texas Instruments TI-92 Motherboard Replacement, Batteries: adım 4, 3 resimden 3.
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Texas Instruments TI-92 Motherboard Replacement, Texas Instruments TI-92 Back Case Disassembly: adım 5, 3 resimden 1. Texas Instruments TI-92 Motherboard Replacement, Texas Instruments TI-92 Back Case Disassembly: adım 5, 3 resimden 2. Texas Instruments TI-92 Motherboard Replacement, Texas Instruments TI-92 Back Case Disassembly: adım 5, 3 resimden 3.
    • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
    FixBot'a Sor
    Yorum Ekle
  6. Texas Instruments TI-92 Motherboard Replacement: adım 6, 1 resimden 1.
    • Unscrew the 19mm screw located near center of the back of the calculator.
    • Remove the panel being held by the screw.
    FixBot'a Sor
    Yorum Ekle
  7. Texas Instruments TI-92 Motherboard Replacement: adım 7, 1 resimden 1.
    • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
    FixBot'a Sor
    Yorum Ekle
  8. Texas Instruments TI-92 Motherboard Replacement: adım 8, 2 resimden 1. Texas Instruments TI-92 Motherboard Replacement: adım 8, 2 resimden 2.
    • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
    • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
    FixBot'a Sor
    Yorum Ekle
  9. Texas Instruments TI-92 Motherboard Replacement: adım 9, 2 resimden 1. Texas Instruments TI-92 Motherboard Replacement: adım 9, 2 resimden 2.
    • Pull out the rectangular module when it is finally loose enough.
    FixBot'a Sor
    Yorum Ekle
  10. Texas Instruments TI-92 Motherboard Replacement: adım 10, 2 resimden 1. Texas Instruments TI-92 Motherboard Replacement: adım 10, 2 resimden 2.
    • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
    • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
    FixBot'a Sor
    Yorum Ekle
  11. Texas Instruments TI-92 Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. Texas Instruments TI-92 Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. Texas Instruments TI-92 Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Pull the motherboard up while holding the rest of the calculator firmly in place
    • The motherboard has now separated from the rest of the calculator
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Maldonado
264 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-51, Garner Spring 2010 Cal Poly, Team 15-51, Garner Spring 2010 üyesi
CPSU-GARNER-S10S15G51
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 40
Her zaman: 4,158
