Ana içeriğe geç
The Beatles Rock Band Drum Set Drum Pad Replacement
Neye ihtiyacın var
  1. The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: adım 1, 2 resimden 1. The Beatles Rock Band Drum Set Drum Pad Replacement, Drum Pad: adım 1, 2 resimden 2.
    • Pry the drum pad off of the drum set.
    • This will take significant force, but the rubber on the drum pad can withstand the force.
  2. The Beatles Rock Band Drum Set Drum Pad Replacement: adım 2, 2 resimden 1. The Beatles Rock Band Drum Set Drum Pad Replacement: adım 2, 2 resimden 2.
    • Remove the small wire clip shown in the picture.
    • If this wire is already disconnected, that is most likely the cause for the drum pad not working.
  3. The Beatles Rock Band Drum Set Drum Pad Replacement: adım 3, 1 resimden 1.
    • Remove the four Phillips size J0 screws supporting the hit sensor.
    • There is a small plastic disk and a spring in the support; be sure not to lose it.
  4. The Beatles Rock Band Drum Set Drum Pad Replacement: adım 4, 1 resimden 1.
    • The sensor can be peeled off of the drum pad.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach Richter
549 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Banghart Winter 2017 Cal Poly, Team 13-3, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G3
4 Üyeler
Bir Yorum
Where can you buy replacement sensor?
Barry Howard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 19
Son 30 gün: 75
Her zaman: 7,976
