Ana içeriğe geç
The Beatles Rock Band Drum Set Front Button Replacement
Neye ihtiyacın var
  1. The Beatles Rock Band Drum Set Front Button Replacement, Front Buttons: adım 1, 1 resimden 1.
    • Remove the four Phillips size J1 screws from the corners of the bottom module.
    • Removing the screws requires a thin screwdriver.
  2. The Beatles Rock Band Drum Set Front Button Replacement: adım 2, 3 resimden 1. The Beatles Rock Band Drum Set Front Button Replacement: adım 2, 3 resimden 2. The Beatles Rock Band Drum Set Front Button Replacement: adım 2, 3 resimden 3.
    • Open the bottom module. Disconnect the five wire clips as shown in the pictures.
  3. The Beatles Rock Band Drum Set Front Button Replacement: adım 3, 2 resimden 1. The Beatles Rock Band Drum Set Front Button Replacement: adım 3, 2 resimden 2.
    • Remove the four Phillips #1 sized screws holding the main circuit board. Rotate the board up and out, exposing the buttons.
  4. The Beatles Rock Band Drum Set Front Button Replacement: adım 4, 1 resimden 1.
    • The buttons can be pushed up from the bottom to be removed.
Sonuç
Zach Richter
549 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-3, Banghart Winter 2017 Cal Poly, Team 13-3, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S13G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 1,175
