Giriş
This guide is for how to replace the directional pad on the Rock Band Beatles Hofner Bass.
Neye ihtiyacın var
Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
Use a J1 Phillips head screwdriver to remove four 5mm long screws.
Use a J1 Phillips screwdriver to remove the six screws 10mm around the brown button cover.
