Ana içeriğe geç
The Beatles Rock Band Hofner Bass Whammy Bar Replacement
Neye ihtiyacın var
  1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Back Plate: adım 1, 1 resimden 1.
    • Flip the bass onto its backside, so that the strummer is facing the table and the battery compartment is facing you.
    • Use a J1 Phillips head screwdriver to remove ten 5mm short screws.
    • Use a J1 Phillips head screwdriver to remove four 5mm long screws.
  2. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 2, 1 resimden 1.
    • Flip the bass to the front, with the strummer and fret buttons facing you.
    • Use a J1 Phillips head screwdriver to remove two 10mm silver, short screws.
  3. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 3, 2 resimden 1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 3, 2 resimden 2.
    • Flip the bass on its back again, so that the strummer is facing down and the battery compartment is facing you.
    • Pull off the back whole panel so that the bass is now open.
  4. The Beatles Rock Band Hofner Bass Whammy Bar Replacement, Whammy Bar: adım 4, 1 resimden 1.
    • Use J1 Phillips screwdriver to remove the four 10mm screws on the whammy bars black cover.
  5. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 5, 1 resimden 1.
    • Remove the black cover.
    • Now the white whammy bar underneath is visible.
  6. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 6, 2 resimden 1. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 6, 2 resimden 2.
    • Use a J1 Philips head screwdriver to remove one 10mm screw.
    • This will unscrew the electrical connection between the whammy bar and the blue circuit board.
    • Remove the electrical connector.
  7. The Beatles Rock Band Hofner Bass Whammy Bar Replacement: adım 7, 1 resimden 1.
    • Remove the whammy bar, since nothing should be connecting to the guitar anymore.
Sonuç
Jacob
601 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-4, Banghart Winter 2017 Cal Poly, Team 8-4, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 685
