Ana içeriğe geç
The Claw Battery Replacement
Neye ihtiyacın var
    1. The Claw Battery Replacement, Batteries: adım 1, 1 resimden 1.
      • Hold The Claw machine upright so that the controls are facing you.
      FixBot'a Sor
      Yorum Ekle
    2. The Claw Battery Replacement: adım 2, 1 resimden 1.
      • Turn the device upside down keeping the controls facing in your direction.
      FixBot'a Sor
      Yorum Ekle
    3. The Claw Battery Replacement: adım 3, 1 resimden 1.
      • Locate the battery compartment door on the bottom cover of The Claw.
      • Loosen the screw from the battery compartment door with your phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. The Claw Battery Replacement: adım 4, 1 resimden 1.
      • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
      • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alain Pierre
1.188 İtibar
9 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G8
3 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 71
Her zaman: 4,290
