Ana içeriğe geç
The Claw Case Replacement
Neye ihtiyacın var
    1. The Claw Case Replacement, Top Cover: adım 1, 1 resimden 1.
      • Place The Claw machine in the up-right position with the control knobs facing you.
      FixBot'a Sor
      Yorum Ekle
    2. The Claw Case Replacement: adım 2, 1 resimden 1.
      • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
      FixBot'a Sor
      Yorum Ekle
    3. The Claw Case Replacement: adım 3, 1 resimden 1.
      • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
      • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
      FixBot'a Sor
      Yorum Ekle
    4. The Claw Case Replacement: adım 4, 1 resimden 1.
      • Turn The Claw machine back to the upright position with controls facing you.
      FixBot'a Sor
      Yorum Ekle
    5. The Claw Case Replacement: adım 5, 1 resimden 1.
      • Remove the top cover of The Claw machine.
      FixBot'a Sor
      Yorum Ekle
    6. The Claw Case Replacement: adım 6, 2 resimden 1. The Claw Case Replacement: adım 6, 2 resimden 2.
      • Remove the ten 6 mm phillips #1 screws from the top flange.
      FixBot'a Sor
      Yorum Ekle
    7. The Claw Case Replacement: adım 7, 1 resimden 1.
      • Lift the flange upward and off to the side of the machine.
      • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
      • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
      FixBot'a Sor
      Yorum Ekle
    1. The Claw Case Replacement, Case: adım 8, 1 resimden 1.
      • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
      FixBot'a Sor
      Yorum Ekle
    2. The Claw Case Replacement: adım 9, 1 resimden 1.
      • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
      FixBot'a Sor
      Yorum Ekle
    3. The Claw Case Replacement: adım 10, 1 resimden 1.
      • Gently remove the broken clear plastic case.
      • Remember how the case sat into the frame so that you can seat the new case in the same way.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alain Pierre
1.188 İtibar
9 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-8, Catania Spring 2016 UMass Dartmouth, Team 4-8, Catania Spring 2016 üyesi
UMASSD-CATANIA-S16S4G8
3 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
where can i get the clear plastic panels
cristian2002 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 47
Her zaman: 2,113
