Ana içeriğe geç
Thermaltake Theron Plus 5-pin USB Cord Replacement
Neye ihtiyacın var
  1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: adım 1, 3 resimden 1. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: adım 1, 3 resimden 2. Thermaltake Theron Plus 5-pin USB Cord Replacement, Top cover: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the plastic cover and pack of weights.
    • Remove the two 1.0 mm foam covers with tweezers.
    • Peel away the plastic screw cover with tweezers.
  2. Thermaltake Theron Plus 5-pin USB Cord Replacement: adım 2, 2 resimden 1. Thermaltake Theron Plus 5-pin USB Cord Replacement: adım 2, 2 resimden 2.
    • Remove the four 1.0 mm screws with a Ph #1 screwdriver.
    • Gently remove the top of the mouse.
  3. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: adım 3, 3 resimden 1. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: adım 3, 3 resimden 2. Thermaltake Theron Plus 5-pin USB Cord Replacement, 5-pin USB Cord: adım 3, 3 resimden 3.
    Satın Al
    • Locate the 5-pin connector on the mouse's motherboard.
    • Use the tweezers to carefully pull the 5-pin connector off. Do this by grasping the connector and wiggling it back and forth until it is off.
    • Once removed, place new 5-pin connector on in the same way.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 647
