Ana içeriğe geç
ThinkPad Edge E31 RAM Replacement
Neye ihtiyacın var
  1. ThinkPad Edge E31 RAM  Replacement, Battery: adım 1, 1 resimden 1.
    • There are two two locks for the battery, one on the left and one on the right.
    • Slide the left lock to the left.
    FixBot'a Sor
    Yorum Ekle
  2. ThinkPad Edge E31 RAM  Replacement: adım 2, 1 resimden 1.
    • Slide and hold the right battery lock to the right.
    • While holding the right battery lock, slide the battery up to remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. ThinkPad Edge E31 RAM  Replacement, ThinkPad Edge E31 Underside Disassembly: adım 3, 1 resimden 1.
    • The battery should be removed before accessing any internal components, and you should ground yourself before handling internal components.
    • Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
    FixBot'a Sor
    Yorum Ekle
  4. ThinkPad Edge E31 RAM  Replacement, RAM: adım 4, 1 resimden 1.
    • The RAM slots are next to the hard drive to the right of the exposed laptop.
    • There are 2 flexible brackets holding each RAM chip in place is.
    • Push these 2 brackets to the sides. This will allow the chips to pop up to a 30° angle.
    FixBot'a Sor
    Yorum Ekle
  5. ThinkPad Edge E31 RAM  Replacement: adım 5, 1 resimden 1.
    • Once freed from the brackets, the RAM can now be easily pulled out of its slot.
    FixBot'a Sor
    Yorum Ekle
  6. ThinkPad Edge E31 RAM  Replacement: adım 6, 1 resimden 1.
    • If your laptop has a second RAM chip in the available slot, repeat the previous 2 steps to remove it.
    • If you are going to be putting 2 RAM chips in your laptop, ensure that they are matching makes and models. This will ensure that you avoid any potential issues that may occur by mixing and matching RAM chips.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Riley
601 İtibar
6 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 577
