Ana içeriğe geç
ThinkPad T420 Hard Drive Replacement
Neye ihtiyacın var
  1. ThinkPad T420 Hard Drive Replacement, Unlock the battery: adım 1, 3 resimden 1. ThinkPad T420 Hard Drive Replacement, Unlock the battery: adım 1, 3 resimden 2. ThinkPad T420 Hard Drive Replacement, Unlock the battery: adım 1, 3 resimden 3.
    • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
    • Unlock the latch locking the battery in the laptop.
    • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
  2. ThinkPad T420 Hard Drive Replacement, Release the battery: adım 2, 3 resimden 1. ThinkPad T420 Hard Drive Replacement, Release the battery: adım 2, 3 resimden 2. ThinkPad T420 Hard Drive Replacement, Release the battery: adım 2, 3 resimden 3.
    • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
  3. ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: adım 3, 2 resimden 1. ThinkPad T420 Hard Drive Replacement, Backup your laptop first!: adım 3, 2 resimden 2.
    • If your build of the OS was installed years ago, you can clone the drive as shown here or reinstall from scratch. However, a reinstallation from scratch will likely be the better choice for older installations with excessive file buildup.
    • Before replacing the drive, backup your personal files. This can be done by hand, or automated.
  4. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: adım 4, 3 resimden 1. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: adım 4, 3 resimden 2. ThinkPad T420 Hard Drive Replacement, Remove the hard drive door: adım 4, 3 resimden 3.
    • EET owners: Your kit has this bit. No purchase needed.
    • Remove the hard drive door from the system. Use a Phillips #1 bit.
    • Once the screw is loose, remove the drive cover as shown.
  5. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: adım 5, 3 resimden 1. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: adım 5, 3 resimden 2. ThinkPad T420 Hard Drive Replacement, Remove the hard drive caddy: adım 5, 3 resimden 3.
    • Pull the black tab on the drive caddy to remove the drive.
  6. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: adım 6, 3 resimden 1. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: adım 6, 3 resimden 2. ThinkPad T420 Hard Drive Replacement, Remove the drive bumpers: adım 6, 3 resimden 3.
    • Remove the hard drive bumpers.
    • Remove the drive screws using a Phillips #1 screwdriver.
  7. ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: adım 7, 2 resimden 1. ThinkPad T420 Hard Drive Replacement, Remove the old hard drive: adım 7, 2 resimden 2.
    • Remove the old hard drive from the laptop. If you intend to keep it, store it in a antistatic bag if possible.
  8. ThinkPad T420 Hard Drive Replacement, Install the new hard drive: adım 8, 2 resimden 1. ThinkPad T420 Hard Drive Replacement, Install the new hard drive: adım 8, 2 resimden 2.
    • Install your new drive using steps 6 through 3. Reinstall or reimage the operating system.
  9. ThinkPad T420 Hard Drive Replacement, Install the operating system: adım 9, 1 resimden 1.
    • If you are installing Windows, use an official ISO or purchase OEM installation media without a product key.
    • In order to save time setting up your system in the future, reinstall Windows from scratch and image the computer once all the drivers and updates are installed.
    • After reassembling the system and confirming the new drive is recognized, reinstall your operating system.
Sonuç
Once you install the new hard drive, reassemble your computer in reverse order. Once you do this, install an OS and restore your data.
6 farklı kişi bu kılavuzu tamamladı.
Nick
93.881 İtibar
59 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
327 Üyeler
1.673 adet Kılavuz yazıldı
3Kılavuz Yorumları
Thank you for the meta notes
commander - Yanıt
Great instructions - you r doing a marvelous job - keep up the fine work !! God bless u !!!!
brixler jandley - Yanıt
Also - love the cat, I also am a cat fan big time !!!
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 31
Son 30 gün: 174
Her zaman: 23,925
