Giriş
"If the computer cannot retain date and time, and gives an error on bootup, then the Real Time Clock battery needs replacement. This guide shows how to perform RTC battery replacement.
The RTC battery is located at the bottom of the mainboard, which will need to be lifted out before the RTC battery can be replaced."
Neye ihtiyacın var
Gently remove battery connector by pushing with the spudger in the direction of the arrow.
Remove five screws holding battery in place and remove battery.
Firstly go through separate battery removal guide. insert straightend paper clip into SIM card holder (arrow) and eject and remove it.
remove 8 screws shown, incl, metal plate over charging connector and the sim card holder.
Wireless LAN RF cables can be left in place.
disconnect all other connectors from mainboard (and tape that fixes the connectors and Flex connectors)
Tip : Take note of magnet location (square) and orientation in case it dislodges. use marker if needed.
Pry up main board gently by lifting the Fan end of the motherboard.
pull board gently toward the fan end to dislodge the connectors from the case and release the main board.
when released, turn over the board to view backside of mainboard.
RTC battery can now be replaced.
Functional RTC voltage is above 3,1V.
Brand new RTC voltage is 3,3V
recommend to tape down loose connectors away from main board while assembling the main board.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Great guide. Thank you Carsten! Might I suggest a small correction to the grammar in the intro? The first paragraph would be better written as
