Ana içeriğe geç
ThinkPad X1 Carbon Fan Replacement
Neye ihtiyacın var
  1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: adım 1, 1 resimden 1.
    • Loosen the seven cover screws. They will not come out.
  2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: adım 2, 1 resimden 1.
    • Use a spudger to pop loose the cover and slide it off.
  3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: adım 3, 1 resimden 1.
    • Only use plastic to remove battery connector
    • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
    • Remove four screws holding battery in place and remove battery.
    • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
  4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: adım 5, 1 resimden 1.
    • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
    • These connectors are very delicate. Use care when removing cables.
    Hi! Does anybody know where to get the little black clip that fixes the fan cable to the connector? Unfortunately I broke it when I removed the fan. Any other suggestions on how to fix the cable are appreciated.
    Jupp NN - Yanıt
  5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: adım 6, 1 resimden 1.
    • Loosen screws and pull fan up and out of the case.
    • Be sure to apply heat sink paste when putting fan back on CPU
    Which generation X1 Carbon is this? I have a 1st Gen and a 5th Gen, neither match this layout. Please updated with the Generation in the title. Thank you.
    Stanislav Valov - Yanıt
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mike
1.834 İtibar
5 adet Kılavuz yazıldı
Ekip
iReconstruction iReconstruction üyesi
Business
1 Üye
11 adet Kılavuz yazıldı
Bir Yorum
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 111
Her zaman: 12,587
