Ana içeriğe geç
ThinkPad Yoga 12 Battery Replacement
Neye ihtiyacın var
  1. ThinkPad Yoga 12 Battery Replacement, Screws: adım 1, 3 resimden 1. ThinkPad Yoga 12 Battery Replacement, Screws: adım 1, 3 resimden 2. ThinkPad Yoga 12 Battery Replacement, Screws: adım 1, 3 resimden 3.
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 Battery Replacement, Prying: adım 2, 2 resimden 1. ThinkPad Yoga 12 Battery Replacement, Prying: adım 2, 2 resimden 2.
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: adım 3, 1 resimden 1.
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 Battery Replacement, Removing the screw: adım 4, 2 resimden 1. ThinkPad Yoga 12 Battery Replacement, Removing the screw: adım 4, 2 resimden 2.
    • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
  5. ThinkPad Yoga 12 Battery Replacement, Lift: adım 5, 2 resimden 1. ThinkPad Yoga 12 Battery Replacement, Lift: adım 5, 2 resimden 2.
    • Carefully lift the battery. There is a small bit of adhesive underneath the green.
    • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
  6. ThinkPad Yoga 12 Battery Replacement, Connecter: adım 6, 3 resimden 1. ThinkPad Yoga 12 Battery Replacement, Connecter: adım 6, 3 resimden 2. ThinkPad Yoga 12 Battery Replacement, Connecter: adım 6, 3 resimden 3.
    • Carefully pull the connector out from underneath the logic board to remove the battery.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
[deleted]
1.324 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 6,560
