Ana içeriğe geç
ThinkPad Yoga 12 SSD Replacement
Neye ihtiyacın var
  1. ThinkPad Yoga 12 SSD Replacement, Screws: adım 1, 3 resimden 1. ThinkPad Yoga 12 SSD Replacement, Screws: adım 1, 3 resimden 2. ThinkPad Yoga 12 SSD Replacement, Screws: adım 1, 3 resimden 3.
    • Remove the ten Phillips screws using a Philips 00 screwdriver
  2. ThinkPad Yoga 12 SSD Replacement, Prying: adım 2, 2 resimden 1. ThinkPad Yoga 12 SSD Replacement, Prying: adım 2, 2 resimden 2.
    • Pry up the case carefully using a spudger.
    • Make sure to not push the spudger in too far, as this could result in internal damage
  3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: adım 3, 1 resimden 1.
    • Lift off the cover, and you're done!
  4. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: adım 4, 2 resimden 1. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: adım 4, 2 resimden 2.
    • Carefully remove two Phillips screws with a Phillips 0 screwdriver
    • Static sensitive components!
  5. ThinkPad Yoga 12 SSD Replacement: adım 5, 2 resimden 1. ThinkPad Yoga 12 SSD Replacement: adım 5, 2 resimden 2.
    • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
  6. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: adım 6, 2 resimden 1. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: adım 6, 2 resimden 2.
    • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
  7. ThinkPad Yoga 12 SSD Replacement, Done!: adım 7, 2 resimden 1. ThinkPad Yoga 12 SSD Replacement, Done!: adım 7, 2 resimden 2.
    • Carefully remove the SSD enclosure.
    • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
[deleted]
1.324 İtibar
3 adet Kılavuz yazıldı
Bir Yorum
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 24
Her zaman: 4,924
