Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Thomas Ride On Train cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Thomas Ride on Train - System Diagram and Components, Thomas Ride on Train - System Diagram and Components: adım 1, 1 resimden 1.
    • System Components
    • When power is applied to the charging connector it activates a relay which disconnects the power to the main circuits.
    • The main powerswitch is under the large yellow lever and simply applies power from the battery to the control board in the console.
    • A multipole switch is used to reverse the direction of the motor
    • An LED in the console flashes with the sound
    • The sound is provided by a loudspeaker in the base
  2. Thomas Ride on Train - System Diagram and Components: adım 2, 2 resimden 1. Thomas Ride on Train - System Diagram and Components: adım 2, 2 resimden 2.
    • Charging Connector
    • The charging connector is on the rear of the train between the buffers
    • My connector is a "old style" connector which is effectively a phono, the new style is a more conventional power connector
  3. Thomas Ride on Train - System Diagram and Components: adım 3, 1 resimden 1.
    • Power Switch and Charging Relay Board
  4. Thomas Ride on Train - System Diagram and Components, 6v Sealed Lead Acid Battery: adım 4, 1 resimden 1.
    • This battery has been replaced, the originals attach via a clip
    • Note the fuse on the positive connector
  5. Thomas Ride on Train - System Diagram and Components, Reversing switch and LED: adım 5, 1 resimden 1.
    • This switch is controlled by the level on the console and switches the polarity of the motor connectors.
    • Middle position is off, the other two positions are forward and backwards
    • If you are replacing the LED don't forget that the polarity of the wires is important
  6. Thomas Ride on Train - System Diagram and Components, Control board: adım 6, 1 resimden 1.
    • Has three switches to activate the music and connectors leading off to the motor, speaker, LED and battery
  7. Thomas Ride on Train - System Diagram and Components, Loudspeaker: adım 7, 1 resimden 1.
    • This is a 16ohm speaker
  8. Thomas Ride on Train - System Diagram and Components, Motor: adım 8, 1 resimden 1.
    • 6v electric motor with capacitor for noise and spark suppressor wired across the terminals
Andy from Workshopshed
420 İtibar
3 adet Kılavuz yazıldı
10 Yorum
sound their but it's stoped moving
Leona - Yanıt
If you've got sound but no movement then the most likely cause is the battery is discharged or defective. If you have a multimeter you could check the voltage on the battery.
If may also be a motor / mechanical issue. With the power disconnected you should be able to rotate the wheels but it won't spin freely as there is a gearbox.
Andy from Workshopshed -
Movement but no sound? Been charged
Shiipwreck Flynn - Yanıt
That could be a problem with the sound board which lives inside the steering wheel. It's quite a challenge to get to that which is what caused me to write the guide in the first place. I had to clean the switches on that board to get mine to work.
Alternatively could be a loose or broken wire on the speaker which is down in the base, one of the first things you get too when stripping it down.
What do I clean it with? Just polish? Had a look. Wires look fine so im confused lol
Shiipwreck Flynn -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 39
Her zaman: 7,442
