Ana içeriğe geç
Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement
Neye ihtiyacın var
  1. Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: adım 1, 2 resimden 1. Thrustmaster T Flight Hotas 4 J1 Screws on Joystick Handle Replacement, J1 Screws on Joystick Handle: adım 1, 2 resimden 2.
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Aaron Banaga
526 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G1
3 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
there are small plastic pieces in mine, when i took it off now my joystick wont work or turn properly and I havent found any guide to where these pieces go??
beardy1 - Yanıt
I'm wondering the same thing right now. That round spring with the arms on it and the black lC shaped plastic piece.
Brent Taylor-Wooster -
On the bottom of the stick assembly you will see a small slot head screw like indent. That is a built in manual stop, rotate 45 to 90 degrees in the loosening direction, it will un lock
Edit: I was trying to include 3 pictures of the assembly and install but no luck sorry
Timothy Brake -
I found this link which shows where that black plastic piece goes: https://channellfd.com/t-flight-hotas-x-...
You know how there are three holes on the bottom of the stick, but only two screws? It goes in the third hole.
HolleringHuskarl -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 28
Her zaman: 3,868
