Ana içeriğe geç
Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement
Neye ihtiyacın var
  1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, J1 Screws on Throttle: adım 1, 1 resimden 1.
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
  2. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: adım 2, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, Throttle Panel: adım 2, 2 resimden 2.
    • Using your hands, pull away the panel from the throttle.
  3. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: adım 3, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement, PlayStation Action Buttons: adım 3, 2 resimden 2.
    • Remove the two 8 mm J1 JIS head screws.
  4. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 4, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 4, 2 resimden 2.
    • Remove exterior panel from the throttle by using your hands to gently pull the panel away.
  5. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 5, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the two 6 mm J1 JIS head screws from the circuit board.
  6. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 6, 1 resimden 1.
    • Carefully remove the circuit board.
  7. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 7, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 7, 2 resimden 2.
    • Remove the 6 mm J1 JIS head screw that is attached to the black plastic cover.
  8. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 8, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 8, 2 resimden 2.
    • Remove black plastic cover.
  9. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 9, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 9, 2 resimden 2.
    • Once the black plastic cover is removed, push the buttons inward from the outside of the device.
    • Be aware of the springs. They are small and easy to lose.
    • This step only replaces the x, square, and circle buttons.
  10. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 10, 2 resimden 1. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 10, 2 resimden 2.
    • Remove the two 6 mm J1 JIS head screws that are attached to the tan plastic cover.
    • Removal of the screws will detach the exterior panel from the device.
  11. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 11, 1 resimden 1.
    • Carefully remove tan plastic cover.
  12. Thrustmaster T Flight Hotas 4 PlayStation Action Buttons Replacement: adım 12, 1 resimden 1.
    • Once the black panel is disconnected, push the triangle button inward from the outside of the exterior panel.
Sonuç
Aaron Banaga
526 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team S2-G1, Bruce Fall 2017 CSU Fullerton, Team S2-G1, Bruce Fall 2017 üyesi
CSUF-BRUCE-F17S2G1
3 Üyeler
13 adet Kılavuz yazıldı
Bir Yorum
Very well presented. Just one question - if one of these buttons (or rather the switch that it activates) has broken, how do you fix it? Where can you get a replacement part if that is what is needed?
Anthony Vallillo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,572
